HELP!! edge printed graphics
ChicagoGraphics
Anyone know the best way of removing Edge printed graphics off a van that are not laminated. I tryed some Vinyl off 104 and it's taking the ink off but not the decals.
I tryed this outdoors, I do have a access to a warehouse but it's not heated but still warmer then outdoors, think that will make removal a bit
easier?
Thanks in advance
+1 to steamer, or a heat gun, and pick at it.
never gonna be easy in this weather, but heat is the only way to make it just a bit easier
Fred Weiss
I never used a steamer before, is there anything I have to watch out for and can this be done outside in 40s F weather?
Yes ... don't burn your little fingers. :ROFLMAO: I live and work in South Florida so I have no idea what it's like to work in 40 degree weather.
ChicagoGraphics
If you saw how many graphics are on this van you would think they would have just wraped it and be done with it. I will take some pictures tomorrow and show ya what I'm up against.
Marlene
blow dryer is what I use. it also depends on the vinyl that is is printed on. if it is Gerber 220, it should be no problem.
GraphixUnlimited
deal with this from time to time as we still use our original edge ( 16 years old and still running like a top )
we use a heat gun to soften her up and start pulling ... usually leaves next to no glue residue. Then we finish the clean off with Rapid Remover.
curious to see pics of this "edge wrap" though
cheers eh
MikePatterson
Head bathroom cleaner.
3m makes some Woodgrain and Stripe remover in a rattle can. You can get it at most auto paint suppliers. Test an area and make sure it will not hurt the finish.
ChicagoGraphics
cheers eh
It's not a wrap, but it should have been, there's 100s well seems like it anyways of decals. Turns out it was printed on a Geber Max onto 3M wrap film, it's coming off easy with a tourch but Im removing it in 40 degree weather in the rain.
MikePatterson
Hope you are charging a premium for the PITA. I would be. Anyway glad it is coming off without much effort.
