Help in Corel 12
Discussion in 'Corel' started by thomchar, May 24, 2006.
  1. thomchar
    thomchar Owner
    133
    Apr 18, 2005
    Yuma AZ
    I had to reformat my hard drive and I can not figure out how I did this before any help will be appreciated. When you type artistic text in corel and then you click on the pick tool it does not show you the height and the width of the text. You can get that information if you convert the text to curves. I had a way of puting another box in the text tool bar that would give me that information and I can't remember what I did to bring that up on the tool bar. Can anyone help me. Thanks in advance Charlotte
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    its a tool bar setting
    Tools/ Options/Command bars/ tick property bar
    That should get you started.
  3. thomchar
    thomchar Owner
    133
    Apr 18, 2005
    Yuma AZ
    Thanks for the help but I still can not figure it out. Charlotte
  4. learned the hard way
    learned the hard way Active Member
    544
    Go to tools/options at the top of the screen. When the options box opens up, go to workspace/customization/command bars...put a checkmark beside "Transform".
    The box you want will probably pop up on the screen floating...just drag it up to the command bar at the top of the screen and put it where you want it.
  5. thomchar
    thomchar Owner
    133
    Apr 18, 2005
    Yuma AZ
    Thank you so much that took care of it. Charlotte Johnson:U Rock:
  6. Joseph Dunkle
    Joseph Dunkle Active Member
    518
    I didn't know it could do that, that is why i was considering upgrading to corel x3(13)
  7. Jackpine
    Jackpine Major Contributor
    Joseph Dunkle There are alot of other reasons to upgrade to X3. It;s worth the price but I went from version 10 to X3.
  8. 2NinerNiner2
    2NinerNiner2 Very Active Member
    1,122
    Mar 21, 2006
    Calgary, AB
    Ditto the upgrade to X3 :) Bought and installed mine last week. Every version now since 1.0 ! :)
  9. Checkers
    Checkers Very Active Member
    2,698
    3
    As much as I would like to stay on top of the latest and greatest with software, I've discovered a long time ago that it is more headaches than it's worth. So, I don't bother with upgrading until the first "service patch" is available.
    If you're still at Corel 10 or 11, I would suggest that you look into Corel 12, which, right now, you can pick up for around $40 if your a smart shopper. Just be aware that it is only compatable with XP.
    Checkers
  10. Techman
    8,520
    8
    38
    Jun 24, 2003
    michigan
    Not this time ol' boy. I am 100% happy with the new X3... There may be a need for a service patch.. But I sure don't see a need for one ..
  11. Jackpine
    2NinerNiner2 , I have used Corel since version 1 also. I jumped from 10 to X3......it was like warp speed. I also got a free Wacom tablet. What a deal at $149.00 and free shipping.
  12. Pro Signs & Graphix
    Pro Signs & Graphix Very Active Member
    2,477
    Checkers - We usually skip every other release but we have to agree with Techman. X3 IS different than 12, not just one or two features but all the way around.
  13. wildside
    wildside Very Active Member
    1,462
    15
    38
    Aug 28, 2005
    Kansas
    we just went to X3 also, jumped from 8 to X3... kept crashing our computer, slammed my fist on the desk, shutter down, next morning it loves me, works like a charm, the contour tool not giving 15 billion nodes makes all the difference, oh and opening .ai files without issue...nice
  14. Si Allen
    Si Allen Very Active Member
    2,146
    1
    Mark....don't forget the Trace in X3....the BEST that I have seen!
  15. wildside
    1,462
    15
    38
    Aug 28, 2005
    Kansas
    yes sir, i went back and re-traced some older designs that i had recreated by hand or with the corel 8 trace....i believe it would have saved at least a couple hours....one or two logo recreations and it will already pay for itself with the time savings....
