HELP just got new Flexi 7.6 and cutter wont cut
Discussion in 'Flexi' started by Pairadice, Apr 14, 2006.
  1. Pairadice
    Pairadice New Member
    6
    :help: I have had my cutter (Seiki 850H) for about 1 month and it came with FlexiStarter (what a waste) everything worked just fine. I just got FlexiSIGN Pro 7.6.1 today and installed it. The program works just fine but I went to cut and the model # 850H was no place. I tried all the other model #'s under Seiki and nothing. Is there a driver I need? Or did I just waste all the money I really didn't have anyway?
  2. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    You could try.........
    in the setup "Hewlett-Packard" "HPGL" which
    could work as a generic device.
  3. myronb
    myronb Active Member
    763
    Go here: http://www.scanvecamiable.com/ under support you can download the updates. You have to register but that's no big deal. I know the updates have additional drivers--I don't know if yours is in the list, but it's worth a try!
  4. Pairadice
    6
    I will try to use that as a grneric device, Shovelhead, Thank you
    myronb, I looked on the website but I couldn't find anything...maybe its there but listed under something else?
  5. Pairadice
    6
    Well the HPGL didn't work either...
  6. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    There is an update for 7.6 v1 you can get it after you log as a user it is on the update page lower left scroll window.
  7. Pairadice
    6
    Is "build731to766updater" what I want?
  8. Dennis Raap
    586
    Oct 5, 2003
    USA
    Go to your Help and then About a window will open and tell you what which build you have.
  9. Pairadice
    6
    My version says build 731
  10. Dennis Raap
    586
    Oct 5, 2003
    USA
    That should be what you need.
  11. Pairadice
    6
    Thanks everyone! I got it up and running
