Moze
Rather than re-type it, I'll just copy and paste info I wrote in another thread:
Not all VHB tapes are recommended for vinyl. Vinyl contains plasticizer which can negatively affect the adhesion of VHB tape.
The only VHB tapes recommended for direct use on vinyl are: 4941, 4945 and 4991. Also, on tapes 4618, 4622 and 4624, the liner side of the tape is plasticizer resistant, so technically those could be used as long as you adhere the liner side on the vinyl and the opposite side on the acrylic.
Not saying that the letters are going to fall off or anything, but if you didn't use one of the tapes recommended, you may want to check in on the sign from time to time and make sure everything is holding.
