Help Please
JONESYS
jonesy
I'M HAVING PROBLEMS WITH ENGINE TURN TUNNELING DEARING CUTTING. AND BLADE IS GETTING COUGHT IN TUNNEL AND RIPPING THE VINYL .TEARING LETTERS ANY SUGGESTIONS OR HELP
THANKS, ERIC :banghead:
JONESYS
jonesy
Reply
SIGN GOLD I HAVE AJUSTED FROM 110 TO 160 JUST TO GET IT TO CUT THROUGH AND IT WAS TUNNELING FROM 110 TO 160 WITH 45 BLADE MY 60 BLADE IS DULL COULD THAT BE IT THANKS FOR REPLY SO QUICK.:thankyou:
signguy95
I use a regular 45 degree blade...the material is so thin...like 1 mil...that any abrasion on the blade could make it tear. What type of cutter are you using?
Jay
Silverado
Release the SignGold from the liner and lay it back down. Then flaten it out with a felt squeegee.
This will keep it from binding/tunneling up.
JONESYS
jonesy
Reply
I'm Using A Roland Sp-540. I Looked At The Blade It Was A Little Dirty. It Is Tunneling All The Way Across The Sheet About 5 To 6 Tunnels As It Makes The Cut.
JONESYS
jonesy
Reply
THANKS, YOU ALL .CHANGED BLADE AND SET PRESSURE AT 100 WENT SMOOTH AFTER THAT YOU ALL ARE GREAT. THANKS AGAIN :signs101::U Rock:
