HELP!!! VersaCamm VP-540i
forty9
I am new to this so please excuse my ignorance!
I just bought a VP-540i. I have Windows 7 Home Premium.
Versaworks loaded fine (I believe) but my computer will not recognize the printer.
Is this because of Home Premium?
forty9
I guess I thought I changed the IP on the printer to match the computer, but it still won't recognize it.
Tigertron
Not familiar with the printer but I do know networking. The ip, if static, should not be the same on both machines. If your computer is 10.0.1.10 make your printer 10.0.1.11 and the subnet mask on both to 255.255.255.0
Restart both
You can check connectivity at a cmd prompt on the computer. Type "ping <printer ip address>"
Mainframe
Make sure when you set the Ip on the printer you hit enter and go back to the home screen on the printer.
versa and your printer are not connected properly. i had the exact same issue when i had to reinstall my os on a new hard drive. i ended up phoning roland tech support and they walked me through it.
dhawkes
Wide Format Fan
Hello 49,
If you register your printer, you can get access to the webinar archive. There are several intro to VersaWork webinars that may be of help. http://www.rolanddga.com/training/webinar/archive/videos.asp
Also, check out our support page. There is access to installation guide and it reviews hooking up to a network starting on Page 40.
http://support.rolanddga.com/_layou...Wide+Format+VersaCAMM+Inkjets&pm=VP-300i/540i
There are also sp[ecific instructions on how ti connect using Windows 7:
http://support.rolanddga.com/docs/D...Guides/RVW_Windows7-InstallDriverManually.pdf
You can also contact our help desk to help walk you through it (800) 542-2307
Best regards,
David Hawkes
Group Product Manager
Roland DGA
DRamm76
Just because Windows Home Premium works NOW doesnt mean it won't give you problems. I love the statement "but it worked before"..ever see those "log off and install updates" when you go to shut down Windows...well those updates could bring you to the "it no longer works" stage.
Most signs are pointing to an IP address, but dont rule out that Windows7 could be the culprit. Roland's Support clearly states NO under Home Premium being supported.
