Help with Black
Discussion in 'Roland' started by TheMattMan, Aug 11, 2006.
  1. TheMattMan
    TheMattMan Member
    120
    Hi all... I am having problems getting a true black to print on some material. It seems to be using all colors to produce black and making it sorta dk brown. Is there a way I can print only black.
    Here is my setup:
    Corel X3
    Versaworks 2.x
    Roland Sp-540v
    Eco-Sol Max inks
    Thanks in Advance.
    Matt
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    yes, your printer will use all colors to make black. Check your color for rgb or cymk code and you will see it is not 100% pure black.
    So set your codes to 100% black and see what happens.
  3. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    Are you having this problem with raster or vector images?
  4. kalvix
    kalvix Member
    312
    1
    18
    Apr 17, 2005
    washington dc
    you may also need to print 25% c 25% m 25% y 75% k to get a nice rich black
  5. TheMattMan
    TheMattMan Member
    120
    I checked my color and it is printing CMY at 0% and K at 100% and it is happening on Vector images.
  6. Shovelhead
    Shovelhead Major Contributor
    10,882
    15
    30% C
    30% M
    30% Y
    100% K
  7. Checkers
    Checkers Very Active Member
    2,698
    3
    First, make sure you're using the right profiles for your image and media.
    From there, I do what shovelhead does. It gives a great black without oversaturating the material.
    Checkers
  8. WB
    WB Active Member
    842
    1
    18
    Feb 9, 2006
    Canada
    C 60%
    M 80%
    y 0%
    K 100%
  9. ezkimo
    ezkimo Member
    38
    where you select your profiles are there any advanced settings that let you print as PURE HUE ?
    If you have it try to mark the black box in oure hue then the printer will print all blacks as blacs
  10. TheMattMan
    TheMattMan Member
    120
    Thanks Shovel.. That helped. It only seems to happen when I am printing on the cheaper calendered stuff.. hi performance always looks how it should.
