Wanna get out of it cheap ?? Get two [2] - 4’ x 10’s of Cor-X, letter it up one color and use some VHB and tape it in place. However, like already mentioned, if you go up there and do anything in the way of making, adding or supplying a sign without fixing that sign, you could be named on a law suit for not fixing a rather large potential safety problem.
Whether you’re a hobbyist, full or part timer, it is your job as a professional to report these things and make sure they are fixed if you’re doing other work to the same area or location. Just because you weren’t asked to fix or was turned down to fix a potential problem doesn’t excuse you from reporting the problem. You could be found guilty of negligence should anything go wrong.
Have them sign a waiver, regardless of getting any work or not. You saw it and responded here about it. So essentially, you recognize the problem. Turning your head is not a healthy thing to do. Not if lives might depend on it.
What if………….
