High Density Urethane adhesive
Discussion in 'General Signmaking Topics' started by ol'phart, Apr 21, 2013.
  1. ol'phart
    ol'phart Member
    74
    Anybody know which adhesive is recommended to glue high density urethane foam 15lb density?
  2. Hytek Tools
    Hytek Tools Member
    27
    1
    1
    Nov 28, 2007
    Baxter, Minnesota
    Hi, I use Gorilla Glue or West System Epoxy for this. Both work well, but with Gorilla you have the expansion and seepage issue as it expands 4 times the volume as it cures.
  3. FatCat
    FatCat Very Active Member
    1,998
    195
    63
    Feb 12, 2007
    Columbus, Ohio
    +1 on gorilla glue - it's what I use, but be watchful of the expansion and I typically use clamps.
  4. mrchips
    mrchips Member
    335
    I use the Gorilla glue as well with a healthy dose of water. Spread glue sparingly on one piece and flood the second with water (and I mean FLOOD). clamp together....white beads will appear quickly. The glue will be set in about 1/2 hour when it looses it's "stickiness". Use a putty knife to remove the "beads". Don't wait!!!!! If you do, the glue will tear out some of the foam along the joint when you try to remove it.
  5. Jackpine
    Jackpine Major Contributor
    +1 for Gorilla Glue. There is a low expansion version but I clamp.
  6. mrchips
    mrchips Member
    335
    The water leaves a softer glue line that won't show when sanded or blasted...... a little side benny. Joe
  7. ol'phart
    ol'phart Member
    74
    Thanks Folks, I new I could count on you
