High temp decals
anotherdog
Does anyone have an idea how I would supply decals that are okay up to 145 degrees?
Is there a material/Laminate?
Robert M
high heat
3M makes a vinyl that is rated that high. I do not recall the part number but we had to go through the industrial division to get it. The end user baked it in a powder coat application.
GARY CULY
i supply various racing engine builders with valve cover decals made of 3651 oracal 210 lam and they hold up fine ..only reason they have to replace ever so often is because parts solvent when cleaning starts to curl edges ..but at 1.50 each they dont seem to mind...
TresL
I have some dealers putting arlon dpf8000 on 2/4 stroke motor cylinders.
They have been on over 6 mos with ALOT of hours on the bike with no issues.
