Colin said:
Hey GraphiXtreme, where are you?
Do you mean geographically, or why am I not monitoring every word here
I'll assume the latter. I had a pretty good sized install today, Sunday of all days. Did some window lettering for a store that's moving, the same business that I may have this sort of "soft partnership" with. Kinda torn as what to charge them, but that's another topic. Install was for two picture
windows, about 8' tall x almost 10' wide each. I put about 6' x 7' on one and about 4' x 7' on the other, mostly 1-color (white) but also had a couple of good portions with burgundy outline. Reason I say all this is if I had a printer, I COULD have printed these 2-color lettering elements. I used Arlon HiPerf white and burgundy at $.68/sq ft for white and $.79/sq ft for colors. Total size for these elements was approx. 2' x 7'. My cost: approx. $21 each. Cost if printed (assuming cast, cuz that's what I used here): approx. $12 each for a savings of $9 each and 1/2 the labor (only weed one and only install one). I'd say that is worth about 1 hour total between cutting/weeding/masking the second color AND installing it, maybe even a bit more (I'm still kinda slow I think). I charge $60/hr so that's about $70 saved for each one (although I don't know if you can say I could have actually "saved" the labor, cuz I am charging for it). But if so, I could have saved myself approx. $140 on this job if I would have printed it myself. Having it outsourced would have been different. Also, if I would have laminated them, that labor savings might be a total wash - so maybe no real savings at all except for an easier install. This is also a case where I'm not so sure printed is any better. Sure I COULD have made the lettering a lot more "whiz-bang" with Photoshop effects and all, but is it value added for something like this?
Now having went thru all that, do you charge the same, or do you charge less (the assumed "savings") and just do more jobs?
On a similar note, I do a fair amount of vehicle lettering installed on
windows. Often times, it just doesn't make sense to print many of the elements that go into them. How do I justify printing in these cases?
Right now, I get a VERY good deal on my wholesale digital prints, so that is another reason I hem and haw around with this. Granted, I could produce them for approx. 1/3 or 1/4 the price, but I also don't have the costs and headaches associated with the hardware & software. I want a printer just the same. I ANALyze the $h1t out of these things, so I don't know where the heck I stand most of the time.
I know that if I had a printer, that I'd push it more, simply because it would be easier and cheaper for me to produce than to outsource. But right now, I don't currently do enough wholesale volume to truly justify it either. Part of that is I just don't push it as much since I want to keep as much profit in my pocket as possible, but also the nature of what I've historically done simply doesn't require a print.
Anyway, enough rambling in this reply, but those are SOME of my thoughts, Colin - in case 60 minutes bores you
