Check the feed rate. Check the heat settings, make sure the head is clean. If this isn't a material you've used before you might have to adjust the feed rate or make sure you roll out what you need instead of letting it pull off the roll. Do you use the plastic end thingys (yes, that's a technical term) on the rolls? That can help the material pull easier. All of this can contribute to the problem...
