Hot and Cold Laminators?
daenterpri
What is the difference between a hot and cold laminator? Or a cold laminator with heat assist? If I purchased a larger format printer and did a lot of automotive type applications, which would I need? I'm looking at buying a Roland SP300V with a 38" Daige cold laminator from a guy... is that a sufficient laminator for my needs?
CS-SignSupply-TT
The difference between HOT and COLD laminators, besides the obvious is the cost of the laminates. COLD laminates typically are 2 to 3 times MORE expensive than comparable low-temp laminates. COLD laminators will be less expensive than HOT laminators to purchase.
