Question How can I change the ink Temperature on Oce Arizona?
Chiki_20
I have a OCE Arizona 350GT and I want to tray with others inks, but for these inks the temperature is high 48°C. I would need decrease the ink temperature. I have the SDS, but I canno´t found where I change it.
Someone knows how I can change?
Grizzly
It’s all about your print!
Will most likely require a service key. One of the reasons OCE bugs me. Limited control of the printer.
SignMeUpGraphics
Super Active Member
Is it not at option 5-1-13?
Documentation says:
5 - Inkbay
1 - Parameters
13 - Ink Temperature Setpoint
Default temperature is 47.0C.
Deymos1981
If still need.
1. Close Calgary and go to Windows. (you need to connect the keyboard)
2. button start / in the line "run" enter "regedit"
3. path hkey_local_machine/software/oce/aries/configuration/calgary_1/inkcontrol
4. On the right, find the line "temperature" and change it to the desired one.
NorthControl
Yes, but be careful with reference temp. It will modificate the head voltage too. The best if you set the ref. Voltages too, and sincronise the ink type too. ...
