Click to Support Signs101 ...
so i have a .5in thick gator-foam board. I cannot seem to get the setting right for it to not cut the material and leave the edges all jagged. does this problem have to do with the bit or speed and depth on the router?
Been awhile since I cut some, but I use a sharp 2 flute straight bit. Plasticrouting.com has good starting point and bit selections. Gator is polystyrene foam in the selector, them 3A.
I have had luck with a super clean edge using a compression bit @ 18krpm, 200ipm, and ø1/4 full cut pass so compression works. Gator foam works great but other foam brands it is pot luck.
Are the interior and exterior edges both jagged? If one is clean and the other is jagged, just reverse your direction while cutting to get a clean edge on your piece.
I also use this bit and have for the last 4 years strictly on gatorfoam. It still cuts clean, well except two-sided prints,the tip is slightly wore out after 4 years.
I have a Zund so the spindle runs at a higher rpm. I run at 50k and 12ips. So if you were to drop that to 18k it would be about 260ipm.
Just realized this .5". I'd just do it in two passes. First at 12ips and the finishing pass at 8ips. That way it removes all of the waste. You can do it in one pass but sometimes it leaves more of a mess to clean up.
We do this all the time with 0.5" and 1" gator. Use an O flute straight bit...not a spiral. The spiral bit will chew up the foam no matter what your speed is. A high speed steel bit will work fine for the soft foam and only cost around $20. 1 pass for 0.5" and 2 passes for 1".
