How do I extract in photoshop and keep just the outlined object?
Discussion in 'Adobe' started by EndlessOptions, May 17, 2006.
  1. EndlessOptions
    EndlessOptions Member
    172
    I have done it before but now I am trying to extract from a .jpg and it does a fine job of extracting but the object that I extracted is in a box and I need to be able to outline it for a contour cut. I have another object that I have already extracted from a .jpg that was sent to me by the same customer at the same time as the one I am working with now and he would like it cut the same as I did the other one. What am I doing wrong?
    :help:
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    what are u saving the file as?
  3. EndlessOptions
    172
    photoshop eps
  4. Techman
    8,520
    8
    38
    Jun 24, 2003
    michigan
    what software are importing this file into?
    If its corel try ungroup and move teh white away..
  5. EndlessOptions
    172
    Flexi
  6. EndlessOptions
    172
    I just imported it into corel and it doesn't recognize it as a group
  7. Ian Stewart-Koster
    Ian Stewart-Koster Active Member
    843
    15
    18
    Sep 27, 2003
    Qld, Australia
    In photoshop, after extracting, select the background & delete or do whatever you need. Use Selection>modify>expand to swell the selection onto the background a bit if necessary then. Use help>export transparency to get it saved as an eps that'll be placeable with the selection transparent.
  8. Cadmn
    Cadmn Very Active Member
    2,859
    Ialways cut the object I want start new file with transparent background & paste then save as file with transparent background just did whole bunch of these for cd case inserts.
  9. EndlessOptions
    172
    SWEET! Thanks, RON
