Need Help How to add bleeds to contour cut?
Parker Dunn
I need to do this as a print and cut, but I don't know the best way to add bleeds to it because of the multi color intersections. Any help would be greatly appreciated! I have Corel Draw, CC, and Onyx.
OADesign
It's kinda difficult to explain here. Post eps and someone can set it up for you if you are game. 1st posts are typically greetings. Hello to you too...
C
ColoPrinthead
Guest
I would use the pathfinder in illustrator to make it a solid object after copying and then offset path feature if you want white around the logo.
myront
CorelDRAW is best
Create a contour of each color, separate then send to back. Still need to go in and mod the nodes in different areas
