How to create a multipage .pdf from .jpgs?
Discussion in 'General Software' started by BlueFishDesigns, May 13, 2010.
  1. BlueFishDesigns
    BlueFishDesigns Very Active Member
    1,714
    Aug 21, 2006
    Huntsville, AL
    I have about 10 .jpg images that I want to put into a multipage .pdf file. I've googled how to do it and I can't seem to find an answer. I've read that it can be done in Photoshop, but not in either version that I have. How do I do it? Thanks!
  2. The Vector Doctor
    The Vector Doctor Very Active Member
    3,498
    144
    63
    Aug 15, 2005
    Ohio
    If you have acrobat pro, it can be done
    file > create pdf > from multiple files
  3. BlueFishDesigns
    1,714
    Aug 21, 2006
    Huntsville, AL
    Unfortunately, I don't. Only Acrobat Reader. :(
  4. Jim Doggett
    Jim Doggett Very Active Member
    1,304
    1
    Or size them in CorelDRAW, add page / template-like surround and any captions, on as many pages as you need and then Publish to PDF. MS Word can do the same, as well.
  5. omgsideburns
    omgsideburns Very Active Member
    2,180
    Apr 15, 2008
    In PHOTOSHOP go to FILE > AUTOMATE > PDF PRESENTATION
  6. BlueFishDesigns
    1,714
    Aug 21, 2006
    Huntsville, AL
    I've read where I can do it in Photoshop but neither of my versions (6 and CS4) have that option.
    I might have a CorelDraw laying around but I'd rather not go through all of the trouble to install it just for this.
    Thanks!
  7. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    I can save files as a PDF in Omega, but not sure if multi pages is possible, does your sign program have any options for PDFs?
  8. tanneji
    tanneji Member
    497
    multiple artboards in illustrator
  9. BlueFishDesigns
    1,714
    Aug 21, 2006
    Huntsville, AL
    Hey Marlene! I have Omega. I didn't think of using that! I'll see if that will work.
    tanneji - I haven't really used the multiple artboards in Illy. I'll see if I can figure that out.
    Thanks!
    Still open for suggestions, too!
  10. imagep
    imagep Active Member
    533
    Dec 1, 2006
    Are you saying that you only have Photoshop installed?
    I have a feeling that if you took the time to instal CorelDraw and/or Word (or any other Word Processor), you would find lots more uses for it. PageMaker, Indesign, Quark will also do what you need. Basically, any program that supports multible pages and will allow you to place a bitmap image in them will work - just install PDF995 (free on their website) and print to a pdf.
  11. BlueFishDesigns
    1,714
    Aug 21, 2006
    Huntsville, AL
    No, I'm saying that I read that Photoshop will do it but neither of my versions have that option. I also have Illustrator CS3 (and CS4 at home) and Omega 3.0.
    Those programs seem to do everything I need.... except this! :doh:
  12. imagep
    533
    Dec 1, 2006
    Even with just a one page document program you can still do it. You could make multple PDF's and then join them with an imposition program such as Quite Imposing. You may also be able to find a free or trial version of a pdf impostion program online.
  13. Marlene
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    I'm not seeing any options for multi pages but you can just stack up all the jpegs and save so it has them all in the same PDF
  14. signgal
    signgal Very Active Member
    1,364
    Dec 29, 2009
    i use PDF995, which is great... but I haven't figured out how to do the multi page deal either.
  15. omgsideburns
    2,180
    Apr 15, 2008
    If you can't figure it out message me... I can take screenshots of where it is in CS3, or just do it for you.
  16. speedneeds
    speedneeds Member
    109
    1
    18
    Jan 29, 2007
    Kentucky
    Here is a video on creating a multi page pdf with Illustrator.
    http://www.youtube.com/watch?v=uodtgSlH5hs
    It runs through kinda fast but gives you a general idea.
    I have found that CorelDRAW usually works best for me.
  17. G-Artist
    G-Artist Active Member
    526
    I did one last week and I am quite sure I used PDF Blender....a free program.
  18. dmatulich
    dmatulich New Member
    8
  19. G-Artist
    526
    Boy, do I feel embarrassed. Ifran is my default viewer and aside from scaling an image or two
    I have never even looked at it for its other uses.
  20. ratchet
    ratchet Member
    30
    Like Jim had said, the most common way I've seen people without acrobat do this is to use MS Word.
    Insert the photos full-size on each page (in the order you want), then go file > save as > pdf/xps
