How to install this sign on brick
jtiii
I paid good money for you to read this!
Hey I'm wondering how to install this sign between brick posts. (The picture has stand-in posts - the actual ones aren't gonna be that ugly!)
I'm making the sign with alupanel faces and returns.
Terry01
Presuming you have a frame, just use anchor bolts directly into the brickwork. Fit the rear panel of the sign after mounting, so no fasteners are visible.
Billct2
If you can design it so one face can be removable you can fasten thru the sides of the cabinet.
If not then you'll probably need some brackets, two on the bottom and two on the top would be least conspicuous and paint to match cabinet and the brick
ams
That sounds cool but does it require one removable face? I'm not picturing it otherwise
You could install the dowels in the sign and then poke in the holes or opposite. Using a spring is the best solution, then you push it in, place the sign and release and the spring will slide it into the hole.
jtiii
That - is fuggin' cool!
