How to make the inside of a word look like a picture
Discussion in 'Gerber Omega, Graphix Advantage & MacImprint' started by PurplePanther, May 8, 2007.
  1. PurplePanther
    PurplePanther Member
    75
    We have Omega version 2.02
    I am trying to put a background image inside of some text
    and print on the gerber. The image also has to print on clear vinyl (reversed)
    How would I go about doing this? I know you can use the
    Power Clip tool in Corel, but is there such a feature in Omega??
    I know under TOOLS you can do some things with DISTORTION but I don't
    think this can be done with this method.
    I would assume you would make the wording change to curves.
    Any help would be greatly appreciated!!!!
    Brent
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,410
    342
    83
    Sep 11, 2003
    Olympia, WA
    It's really much easier than all that.
    • Open your image in a workspace.
    • Set your text with no fill or stroke
    • Assign both the image and the text to be on clear vinyl
    • Press F8 to preview the job
    • Output to GSPPlot
    • In GSPPlot open the 123 dialog and assign a "basecoat white" and reverse the print order
    • In GSPPlot reverse the image
    You should be good to go. there are other ways to do this but this is the easiest.
