hp 9000s error 1290
monny
started the printer today, did the cleaning and test, now come up with "system error 1290- power off/on". Turn off and on, same thing.
theretzlaff
your trailing cables are bad, i replaced my last week i think it was around $250, HP is out of them, order them from seiko they have them in stock.
HulkSmash
This actually means your print heads are running too hot. Make sure your Fans on your cartridge are working.
tbaker
that is printer error 120x not 1290
HP is pretty specific about these error codes since there are so many parts that can, and will go wrong.
From the service manual;
System Error: System Error 1290: End of Life of Part Reached
Problem Description: The end of life of the Prime Assembly has been reached since it has been working for more than 58 hours.
Corrective Action: Try the following: Replace the Prime Assembly ⇒ Page 8-155.
HIGHTEC
error code 1290... HP 9000
yes, I had a client that had the same problem, error code 1290 flash on the screen. Froze the machine up, you have to go into Main. Mode and reset counters.
Hightec Digital
Robert Bradley
Folsom, Ca
:cool1:
cheez_cb
hp 9000s
Hightec Digital
Robert Bradley
Folsom, Ca
:cool1:
Hello, can you help me on how to reset the counter?
thanks
wunder
power up with holding Shift + Cancel
input maintenance Passwort
left right shift
scroll to counters with shift
thats it have fun
br
wunder
