Enough of the technical stuff. I'm stupid when it comes to making profiles and adjusting things. But I do know about
the everyday running of the machine.
First, I had a Roland Versacamm. We bought the Hp 360 about 8 mos. ago
We decided to buy the 360 over the 310 because they said it was faster and I liked the idea of the touchscreen. I don't think the 310 has a touchscreen. As far as speed, the 360 is faster printing ( when it's printing ) but the startup time and the cool down time added to the print time doesn't seem to make it much faster than my Versacamm.
But a big plus is the ability to take it off the machine and laminate it immediately. When we used the Versacamm, we tried to let prints dry overnight and we had them hanging all over the shop. Another plus is the take up reel. We can literally run hundreds of prints onto the take up. We can move the entire spool from the take up right to the laminator.
Now for the cons... Heat... Heat... Heat... It gets hot in the room. And lately, it's been fogging up the
windows. So much that we turn the heat off. May be a good thing. You need to install 2-220 electric outlets. It seems that it must use a lot of power. I can't tell because just before we bought the machine, we were trying to reduce our ridiculously high electric bill
We changed the lighting and air conditioning compressor on the roof. So our bill is much lower. I can't tell how the new machine has affected the bill.
It seems that some materials curl from the heat and cause jams as it goes through the heater.
If I leave material in the machine overnight, it may jam when starting up in the morning, but I leave it in and take my chances because... Loading material is a pain. The versacamm loads from the back. It was easy to load.
This machine loads from the front. You have to actually bend over and look up into the machine to load it. Not something someone my age wants to do everyday. However, I found a stool the nail girls use when their manicuring nails. You sit on it and it's the perfect height. My other option is the 25 yr old that works for me. He makes short work out of it.
What about rip software. I used the Versaworks software for 10 years. Simple and to the point. But only works with Roland.
I think the HP 310 comes with a version of Flexi
sign. If you buy the 360, you need to supply a rip. BTW, Flexi does a very good job with HP.
So, if I going to buy again, what would I buy ? Even after all the cons with the HP, I would buy it again. I like the fact of laminating right away and the take up. However, I would consider the 310. It costs less and maybe I don't need all the bells and whistles. It seem I don't know how to use most of them
