Click to Support Signs101 ...
Might try ebay used - these are commonly used by copier equipment companies for leased copiers. I bought one that had the incorrect plug; replaced with NUMA 6.
Voltage drops as it travels from the main transformer, so if your building is the first connection to the power line your voltage can be as high as 250 volts like mine is and if you are at the end of the line it can be 200V. This is perfectly acceptable the to power company and they will not do anything to fix it. We installed two buck/boost transforms on separate GFI breakers.
