Ryan Scott
I know how to do double sided prints when the image is the same on both sides. Any tips or tricks on doing it when the print is a different image? I'm using Onyx Poster Shop. I know it's not really "supported" but can be done.
The error comes through on OnyxI'm not sure about the 370 but I know that the 570 has a camera on the bottom that looks for a registration mark. When loading the material I think that it's an option on the printer menu.
Does Onyx allow you to control Side A on the printer?
Sounds like an Onyx issue so may be best to call Onyx support.
Why not just implement Side A and Side B on the printer and print from Onyx like normal. Rotating Side B if necessary. I have two RIPs I can run the L360 with and neither one control double sided printing, but implementing it on the printer works fine.
If it is crunch time get some single sided block out 64" (assuming your printer is 64") material and run the front and back side to side - tent fold (long side) and glue or stitch. Not the most elegant but will get the most material through the printer in the shortest amount of time with the least chance of a print error or jam.
wayne k
guam usa
If that was an option but we have been burned by our backups, most often not being able to get remotely close on color settings and they were both running same rip and same printer.for a 190 of them in 8 days I would look for a backup solution (outsource)
