HP Latex 670 a hoax?
Discussion in 'General Chit-Chat' started by StickerGuy83, Dec 2, 2020.
  1. StickerGuy83
    StickerGuy83 Member
    54
    2
    8
    Sep 25, 2019
    new jersey
    Rumor has it HP was going to release a 64" roll to roll latex printer that has the capability to print white ink. Rumor is, they're dubbing it the "670" with a hefty price tag to go with it. Anyone hear any news on the release date?
  2. tudouqiezi
    tudouqiezi Member
    31
    5
    8
    May 23, 2017
    China
    According to my sources, the 3L version is priced above $60,000 in my area.
  3. balstestrat
    balstestrat Active Member
    640
    98
    28
    Aug 25, 2020
    Between the bits
    Would not be that expensive elsewhere, maybe half that price. It would be a suicide with that price tag.
  4. tudouqiezi
    tudouqiezi Member
    31
    5
    8
    May 23, 2017
    China
    I really need the white ink so badly, and if this is the case after the release I will not hesitate to buy ucjv300.
    • Hilarious! Hilarious! x 2
    • Pure Genius! Pure Genius! x 1
  5. Commando
    Commando Member
    296
    17
    18
    Oct 11, 2013
    Tennessee
    That heap of junk will no doubt be expensive.
  6. StickerGuy83
    StickerGuy83 Member
    54
    2
    8
    Sep 25, 2019
    new jersey
    I recently visited Mimaki. Saw every machine they make. For what I do, it is not a good fit. The ink is raised on the media, and is thick. If your in the signage/wall/window graphics niche, it would a good choice. Especially with the 5 layer printing and the effects with backlit. Decent scratch resistance, but not as good as HP Latex. The UJV-100-160 prints faster than the the UCJV, but its only capable of 3 layer printing. When you purchase the machine, you have to decide which way you want to print white ink. It can either be setup to print under, or ontop. You cannot have both (UJV). Now with the UCJV, you have the option. But the UCJV is a turtle when it comes to speed. It is actually slower than the UJV. Clear option is not printed during the normal passes. It has to print the whole job, than roll back and lay clear over it. This applies to special effects as well. Rasterlink and setting up the white will probably take a lot of training and learning curve, it all seemed pretty complicated to me (I use flexi). Also, if you do print and cut, you will have to import your cut lines into the RIP with Corel or Ai. it does not have the ability to add reg marks, if your using non Mimaki cutters.
    When the new HP is released (hopefully in Feb), it will be a 64" roll to roll with the white option and bulk ink option as well. I'll most likely purchase one for both of those features.
    • Agree Agree x 1
  7. bigben
    bigben Very Active Member
    1,677
    75
    48
    Sep 3, 2007
    Quebec
    I'm also waiting for the new HP to change my printer. Right now, the mimaki ucjv is my first contender.
  8. StickerGuy83
    StickerGuy83 Member
    54
    2
    8
    Sep 25, 2019
    new jersey
    You can get a 54" UCJV print and cut for around $20,000 USD. But again, for what I do, its not a good choice. The new HP will definitely be much more expensive.
  9. bigben
    1,677
    75
    48
    Sep 3, 2007
    Quebec
    We do mostly backlit, murals, windows and small decals. So in my case, the printer is perfect. But I'm waiting for the HP to see what they will offer.
  10. StickerGuy83
    StickerGuy83 Member
    54
    2
    8
    Sep 25, 2019
    new jersey
    Seems like the Mimaki might be the better option. Although, the latex R series is capable of 5 later printing, so I am going to go out on a limb here and assume that the new HP roll to roll will have the same options, which in your case, will work very well. It will boil down to the price point. HP is probably going to come in high, which I feel will hurt them in the long run. The Mimaki pricing is really good.
  11. TomK
    TomK Member
    442
    41
    28
    Sep 22, 2015
    Virginia
    How was the print quality of the UCJV compared to the grainy stuff the HP puts out due to the droplet size?
  12. StickerGuy83
    StickerGuy83 Member
    54
    2
    8
    Sep 25, 2019
    new jersey
    I wouldn't say the prints were "grainy" with the UCJV, but it does look "textured". I've been able to eliminate a lot of grain with my latex printers by doing a series of things, which I won't get into right now, but for what I do, the Mimaki just isn't a good fit. The LUS170 inks have a decent scratch resistance, but nothing like Latex. The only difference between LUS170 and LUS210 inks are the "stretchability" if you were using it to print vehicle wraps, then it would make sense to use the 210. Image quality is nice, but I can't get over the fact that the inks cure quite thick ontop of the substrate. And that's only printing one layer. Imagine you printed decals with white layer, cmyk layer and a clear layer, it would literally feel 3D. My customers would not like it at all. Also, the LUS inks print with a matte finish. In order to get a glossy ink effect, you have to use the clear. It would take forever and a day to print a roll with the Mimaki that way. Keep in mind, the clear doesn't go down during printing, it has to roll the job back and lay the clear after the job was printed. When your printing roll to roll daily, this printer would be a nightmare when it comes to volume.
    • Informative Informative x 2
  13. gelink
    gelink ink jet specialist since 30 years in France
    25
    1
    3
    Jun 20, 2013
    france
  14. gelink
    25
    1
    3
    Jun 20, 2013
    france
    yes in february
