Click to Support Signs101 ...
Hi i have a problem, with every color is allright when drying with 8 passes and 113 temp. but only blue ink is not drying properly. It leaves like wet stains.
What material? Raise to 116 and add 500ms interpass delay. See if that helps.
Then you can try to lower it or switch to 10-pass. You probably have a very dark blue image with a lot of color?
got pictures of these "wet stains"? could just be a media issue and you're only noticing it in certain colors. The plastic in older media becomes imperfect/mottled and will resist ink in blotchy/rain-spotted patterns.
