HP Scitex FB550 Magenta Head wont fill
DJAvocado
Hello there, I am trying to get my printer up and running. Little background I changed my magenta ink box out prob two weeks ago. Everything was running fine until about a week after. I started getting an error message saying my magenta printhead is empty. With a printhead error it won't allow you to print anything. So I started checking everything, I have checked the magenta ink lines, there is ink past both of the filters. I primed the ink pump and felt it running good. After that I saw it could be a bad thermistor, bought one of those and replaced it, making sure that the O-ring was installed correctly. I did notice a little ink in the reservoir when I did this. After this I figured it would work, I go to the fill printhead procedure, and it tells me again it can't fill the printhead. Specifically it tells me the magenta reservoir cannot be filled. At this point I'm not for sure what to do, any help would be greatly appreciated. Thank you all
DJAvocado
UPDATE: I tried the printhead fill procedure again and this time it got up to 12% complete and I saw with my own eyes ink coming out of the printhead. Unfortunately, it stopped, and I still have the printhead reservoir is empty error message
DJAvocado
UPDATE: Still no progress, I've called someone who messes with these FB 550's a lot and they are thinking the bottom of my reservoir is clogged. At this point I'm hopeful someone on here has had a similar problem
Lucid1303
It could also be a pressure issue. If there's a compromise anywhere in the system it could think its outputting more ink than it actually is due to the pressure seeping out somewhere. Also it could be a faulty pump. I know the FB500 uses one pump for all colors but you could be experiencing issues early with the magenta line bc it was lower than the others. But i'd verify that the line, sensors, and valves for the magenta track is all good before expanding outside of that. The 3 sensors I would test first would be the Ink Resevoir Pressure Sensor, System Pressure Sensor and the Resevoir Level Sensor.
DJAvocado
Thank you for the response, I gave up on it for the moment just needed a break. Gonna check those three sensors once I start messing with it again.
Glavin_ID
Same exact thing happened to me recently on my FB700 with yellow ink. Replaced a pump, filters twice, thermistor, and it started working when we changed ink manufacturers. Tech I talk to thinks it’s bad ink, not viscous enough. Ink manufacturer claims “it’s all within tolerance” after we went back two partial boxes for testing. Hard to tell what the fix was because we did so many things but I feel like it was the ink. I spent so many hours trying to find/fix the issue. What ink are you using?
DJAvocado
From everything I've done Im starting to think the ink is bad as well. Atm I am using budget inks, haven't ever had problems with it before but all this happened about a week after changing ink box. I've contacted them and they "assured" me that the batch was up to code. Couldn't get them to even send me one box to try, with me willing to send old box back. I've replaced the thermistors and ink pump.
Lucid1303
yeh i wanted to mention this before but forgot to lol. Just bc you ran the machine for a week after changing your ink to the new box doesnt mean it was running from the new box. Depending how low it was when you changed it out, what was in there could be residual ink in the res. and line from the previous box. So yeh bad ink is another good culprit. We've been using Nazdar 705 inks in our FB500 for about 3 years now and love it. Just remember if you swap manufacturers to double check your colors after printing.
