I need help with this Edge part PLEASE!
eye for signs
My Edge was, let's say altered, and I need to identify and find out where to purchase this part. Any help would be awesome! It's the black item on the right that is missing on mine. Please and Thank you!:smile:
round man
I see a blue heat shrink insulated component held on by wire ties ,...could it possibly been moved during the "alteration" you mention,..it appears to be either a component installed inline attached to wires on each side and or a connector that has been insulated with blue heat shrinck and possibly moved elsewhere
Tony Teveris
I assume this is a Edge II - on older units we had some problems with the foil motors and we added this kludge (fix), at some point we changed the motors and this was no longer needed. That's all I know. If you want more detail you should call service with a model number, etc
eye for signs
Thanks...
The machine was spitefully reconfigured so I'm trying to figure out what was removed and such. Someone mentioned to me it was a capacitor possibly...
Thoughts anyone?
Billct2
How do you know that's the part that's bad?
I would take it out and head to an electronics supply house and see if they can match it.
tamiya
Looks like 2 ferrite bead/tunnels thru which the slew motor wires are threaded thru,
not electrolytic capacitors...?
