Pro Signs & Graphix
Sibole - Welcome to Signs 101.
Whether or not you make a go of it is soley up to you. Be forewarned that it is not as simple as everybody thinks and every minute that you put into learning will be a minute taken from family - no ifs ands or buts about it.
That said...do yourself a favor and avoid the cheapy plotter ESPECIALLY if you want to do shirts. Cheapies CANNOT cut small and fine, not even the Creation - something that is necessary when doing shirts. Here is a tip, whatever machine you buy MAKE SURE that it has servo motors NOT stepper motors. It is too detailed to explain why, so we are asking you to take our word for it.
As for explaining the initial investment to your hubby, let us put it this way. Cheapy stepper driven plotters are the equivalent of cheap and inaccurate chinese $1.00 tape measures, while servo driven machines (name brand: Summa, Graphtec, Ioline, Roland) are the equivalent of Stanley tape measures. If he does not understand the difference between the two, then we cannot help, as you are in for a very steep uphill ride.
Before you invest in a machine, you should invest in books and Corel Draw. We do not care how much time you believe you have, if you do not TRULY know the software and understand the principals of SIGN layout (there is a difference), then you are dead n the water.
We hope this helps - good luck.
