i1 Xtreme Problems
jasonx
Hey guys,
I have a problem with my i1. I have tried using the online support from xrite and lodged trouble tickets but I haven't had a response in over a week.
My diagnostics tests fail at the lamp test stage. Further if I try to use the i1 in versaworks etc I get an error due to it not being able to calibrate.
This is a brand new package I bought about 3 weeks ago.
Diagnostics dump:
I have a brand new i1 xtreme package. It fails to pass diagnostics.
  1. General Information
  2. Date and Time: 11/24/2009 10:37:27 AM
  3. Application version: Version 2.5.1
  4. SDK version i1: Version 3.4.0 Build 131
  5. SDK version iO: Version 1.1.2 Build 100
  6. SDK version iSis: Version 1.0.5 Build 70
  7. Platform: Microsoft Windows XP Professional x64 Edition, Service Pack 2
  8. Device Information
  9. Device type: i1Pro (NO filter) [ Ambient Light Emission Reflectance Reflectance Scan Flash ]
  10. Serial number: 339561
  11. Firmware version: 505
  12. CPLD version: 999
  13. Dark measurement count: 106
  14. Lamp burning time: 54.6331 seconds
  15. Spot measurement count: 67
  16. Scan measurement count: 6
  17. Dongle Test
  18. Module "Scanner" is licensed
  19. Module "Monitor" is licensed
  20. Module "Printer" is not licensed
  21. Module "Printer RGB only" is licensed
  22. Module "Printer CMYK only" is licensed
  23. Module "Beamer" is licensed
  24. Module "Printer Easy RGB" is licensed
  25. Module "Printer Easy CMYK" is licensed
  26. Module "Digicam" is licensed
  27. Module "Editor" is licensed
  28. Button Test
  29. Button is working normally
  30. Calibration
  31. Emission calibration: Successful
  32. Emission Test
  33. White measurement: Successful
  34. Gray measurement: Successful
  35. Black measurement: Successful
  36. Red measurement: Successful
  37. Green measurement: Successful
  38. Blue measurement: Successful
  39. Emission Test: Pass
  40. Dark measurement
  41. Dark measurement: Pass
  42. Noise Measurement
  43. Noise measurement: Pass
  44. Lamp test
  45. Reflectance calibration: Not successful
  46. Reflectance calibration: Not successful
  47. *** FAIL ***
  48. **************************
  49. General Information
  50. Date and Time: 11/24/2009 10:37:27 AM
  51. Application version: Version 2.5.1
  52. SDK version i1: Version 3.4.0 Build 131
  53. SDK version iO: Version 1.1.2 Build 100
  54. SDK version iSis: Version 1.0.5 Build 70
  55. Platform: Microsoft Windows XP Professional x64 Edition, Service Pack 2
  56. Device Information
  57. Device type: i1Pro (NO filter) [ Ambient Light Emission Reflectance Reflectance Scan Flash ]
  58. Serial number: 339561
  59. Firmware version: 505
  60. CPLD version: 999
  61. Dark measurement count: 106
  62. Lamp burning time: 54.6331 seconds
  63. Spot measurement count: 67
  64. Scan measurement count: 6
  65. Dongle Test
  66. Module "Scanner" is licensed
  67. Module "Monitor" is licensed
  68. Module "Printer" is not licensed
  69. Module "Printer RGB only" is licensed
  70. Module "Printer CMYK only" is licensed
  71. Module "Beamer" is licensed
  72. Module "Printer Easy RGB" is licensed
  73. Module "Printer Easy CMYK" is licensed
  74. Module "Digicam" is licensed
  75. Module "Editor" is licensed
  76. Button Test
  77. Button is working normally
  78. Calibration
  79. Emission calibration: Successful
  80. Emission Test
  81. White measurement: Successful (X=186.583 Y=198.405 Z=178.026)
  82. Gray measurement: Successful (X=108.667 Y=116.777 Z=119.863)
  83. Black measurement: Successful (X=0.255 Y=0.263 Z=0.385)
  84. Red measurement: Successful (X=93.568 Y=49.271 Z=2.087)
  85. Green measurement: Successful (X=63.526 Y=129.888 Z=17.464)
  86. Blue measurement: Successful (X=30.039 Y=19.661 Z=159.047)
  87. Emission Test: Pass
  88. Dark measurement
  89. Dark measurement: Pass (-199.922)
  90. Noise Measurement
  91. Noise measurement: Pass (3.234)
  92. Lamp Test
  93. Reflectance calibration: Not successful (I1_Calibrate failed: New integration time: No light
  94. ::GretagMacbeth::DeviceDriver::Generic::Calculation::DriverCalculation::NewIntegrationTime(): ..\..\..\..\Generic\Calculation\DriverCalculation.cpp:573
  95. ::GretagMacbeth::DeviceDriver::Generic::Calculation::DriverCalculation::NewIntegrationTime(): ..\..\..\..\Generic\Calculation\DriverCalculation.cpp:599
  96. ::GretagMacbeth::DeviceDriver::Generic::Measurement::RemissionHandle::Calibrate(): ..\..\..\..\Generic\Measurement\RemissionHandle.cpp:199
  97. ::GretagMacbeth::DeviceDriver::i1::EyeOne::Calibrate(): ..\..\..\EyeOne.cpp:247
  98. ::EyeOneSDK::EyeOneSDKProxy::Calibrate(): ..\i1.cpp:159
  99. ::I1_Calibrate(): ..\i1_c_sdk.cpp:134
  100. ::GretagMacbeth::DeviceDriver::I1T::i1Bridge::I1_Calibrate(): \src\i1Bridge.cpp:163
  101. ::GretagMacbeth::DeviceDriver::I1T::i1TableSDK::I1_Calibrate(): \src\i1TableSDK.cpp:210
  102. ::I1_Calibrate(): \src\i1T_c_sdk.cpp:140)
  103. Reflectance calibration: Not successful (I1_Calibrate failed: New integration time: No light
  104. ::GretagMacbeth::DeviceDriver::Generic::Calculation::DriverCalculation::NewIntegrationTime(): ..\..\..\..\Generic\Calculation\DriverCalculation.cpp:573
  105. ::GretagMacbeth::DeviceDriver::Generic::Calculation::DriverCalculation::NewIntegrationTime(): ..\..\..\..\Generic\Calculation\DriverCalculation.cpp:599
  106. ::GretagMacbeth::DeviceDriver::Generic::Measurement::RemissionHandle::Calibrate(): ..\..\..\..\Generic\Measurement\RemissionHandle.cpp:199
  107. ::GretagMacbeth::DeviceDriver::i1::EyeOne::Calibrate(): ..\..\..\EyeOne.cpp:247
  108. ::EyeOneSDK::EyeOneSDKProxy::Calibrate(): ..\i1.cpp:159
  109. ::I1_Calibrate(): ..\i1_c_sdk.cpp:134
  110. ::GretagMacbeth::DeviceDriver::I1T::i1Bridge::I1_Calibrate(): \src\i1Bridge.cpp:163
  111. ::GretagMacbeth::DeviceDriver::I1T::i1TableSDK::I1_Calibrate(): \src\i1TableSDK.cpp:210
  112. ::I1_Calibrate(): \src\i1T_c_sdk.cpp:140)
  113. *** FAIL ***
I've tried 4 different computers. Tried all the usb ports. I even purchased a usb hub with external power. All the diagnostics run the same way.
Can anyone shed any light on my problem short of me returning the package?
The white tile is 'married' to each i1 Pro unit at the time of manufacture. As you have experienced, if the white tile is damaged (or in this case dirty), it becomes pretty useless.
Glad to hear that you got it sorted out.
astro8
"I get an error due to it not being able to calibrate"
I just read that and was gonna tell you to clean the tile!..Don't worry about it, happens more often than you think..we've all been there..
jasonx
Didn't occur to me it being brand new. Live and learn I guess :)
