ICC Profiles for 3M 50/50 Perforated Window Film
ADuke
Hello,
We are trying to print a solid black on perforated window film and it is printing about 10" of media and then head strikes appear. We are thinking the heat settings are too high but can not find a profile for this media or one similar that works. What profile do you use (we are printing with an HP Latex 360 printer)?
Thank you in advance!
Asuma01
In my experience its the vacuum setting you want to adjust. Crank it up first before adjusting heat settings.
I use a slightly adjusted 40-20c media profile. The difference being way higher vacuum pressure.
ADuke
Do you know what the vacuum pressure is set to for that profile? I bumped the vacuum all the way up to 50 and the heat settings are set at 195. The original settings were 237 degrees and 35 vacuum and still isn't working....
Asuma01
keep turning it up until headstrikes stop. Or if you max it out and still get head strikes then switch to a different brand of perf. I've used clear focus perfs with good results.
ADuke
So, It ended up not being the profile. I have the settings at 35 (vacuum), the heat at 196 and it is now printing perfectly. The difference being "Output Platen Protector" Kit. I spoke with someone on the phone and they recommended using these. I have never used them before but it seems to have done the trick. It may have also been that we switch the plates in the machine to try to print edge to edge, probably just can't do that with window perf. Once the platen and edge holders were installed that seemed to help too. I guess lesson was, no edge to edge with window perf and use Output Platen Protector when printing.
