Illustrator can't fit my design
TheSnowman
I'm trying to make a layout that is 5' tall, by 28' long. Illustrator just takes a dump all over itself when I tell it to go that big, and tells me it doesn't know how. It's CS2, but I've never had to make anything that big before...any ideas on a way around this? It's just going to be some vectored lines that I'll be cutting on the plotter.
TheSnowman
I considered that, I was just annoyed that I had to scale it. Just wondered if there was an easy way around it...not that scaling it will kill me.
Fred Weiss
Although Adobe Illustrator is an excellent design application, its authors do not gear it to accommodate larger sign sizes. Scaling is the solution.
GK
CS3 was supposed to allow larger art board sizes but that obviously fell through =/. CADTools or Scaling will be your only solutions.
thewood
That's always been a drawback (in my mind) with Illy and PS--the inability to accomodate large layouts. Of course, you can scale things up, but should one have to? This is one area where Flexi blows Adobe products away.
iSign
hint: try 10% instead of 25%. Just move the decimal & every measurement you enter, or every measurement you read takes absolutely no time to calculate, only the nano second to remember that you are scaling at all.
this is one area where Flexi blows Adobe products away.
I love both products, but after 15 years of scaling signs in Illustrator, this comment makes me laugh...
...to me this extra 5 seconds of scaling represents one tiny chink in Adobe's armor, not significant enough to contribute one iota to who blows who away :rolleyes:
There Foz... hope I gave back the right words :smile:
GK
Keep in mind, Flexi was designed primarily to do decal/sign work so if Flexi was designed to do this and couldn't make graphics this size...what use would it have at all compared to any of the Adobe products. Adobe wasn't created to cut decals, design wraps, make signs so there was absolutely no need for anything like this for them to make changes, hence all the 3rd party stuff out to do the stuff it originally wasn't intended to do.
iSign
ummmm... let's see...
don't fill 22 shells with firecracker powder and torch in moms wreckroom
don't jump of 40' rope swings at scout jamboree
don't ride with friends driving on qualudes
don't freeze up in the impact zone in high surf advisory conditions & let the lip drive your ribs into your board
don't catch an edge boarding down the treeline
without further ado ...guess I'm gonna say no :rolleyes:
thewood
Adobe wasn't created to cut decals, design wraps, make signs.
Exactly.
CS3 only scales up to 18.9618 FT
And, somtimes, that just isn't big enough!
I use both Illy and PS on a daily basis, so I'm not bashing them. However, Flexi is still my go-to vector based drawing app. I think it's geared more towards the precise measurements involved in signcrafting than Illustrator.
Rick
Scaling in any program has its advantages...like sending a proof and using the scaled drawings to measure your lettering placement...that is the majority of my work. I have not had too many issues with precision when scaling up. When I was a production monkey I saw the same mistakes when getting Corel, Flexi, Quark and other files. By the way, printing out in scale from Flexi blows. Since I design for multple uses and CadTools has more options, Illustrator has more advantages for me....if I was cutting vinyl all day or had no reason to use scale then I would think it sucks too. I have the scale thing down in my head...8.333 for getting it into Architects scale 10's for metric...then fit in a page..no biggie
Deaton Design
I do just about every single layout in illustrator in a scale size. If its for a 4' by 8', I design it in 4" by 8". I import the file into vinylmasterpro, resize it and cut everything from there. I hardly do any design work in my cut program.
