Why not just open the eps in Illy instead of placing it?
If it is a vector based eps there should be no issues
Is the eps actually just a jpg or tiff embeded in an eps format?
That would explain the box?
I can take a look at it for you if youd like, you can PM me for my email if
It's a tiff as an eps file. Since you idea made perfect sense to try just opening & then placing in file. Yet problem is still there. Were on the phone w/Adobe now. We pay then plenty for program, let's see what they arrive at.
I can tell you the problem right here, eps does not support transparency when saved for output, the best solution is to "clip" the image in Photoshop and save it with a clipping path, then you can place it into Illy
