illustrator help with Resolution
Discussion in 'Adobe' started by LMSigns24, May 27, 2008.
  1. LMSigns24
    LMSigns24 Active Member
    567
    1
    18
    Nov 1, 2007
    Pa
    Hi, I have created a brochure in illustaror for a customer. When i print it out on my printer, it is very clear. I am sending it to a printer to get printed, but they are telling me the file is only 72dpi. I saved it for them as an eps. How do you chanage the resolution in illustrator? I am under the assumption that since it is vector they should not have a problem with resolution. I have never had this problem before. What is going on?
  2. Rodi
    Rodi Very Active Member
    1,333
    1
    38
    Aug 3, 2007
    Hi LM,
    is there a picture involved that you imported? Any type or vector piece would be resolution independent, so only raster items are a concern.
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,566
    423
    83
    Sep 11, 2003
    Olympia, WA
    If it's all vectors then you need to talk to your printer. Vectors are resolution independent. If any portion of the file is raster, however, then you may need to look at the size of the original raster image in Photoshop or any other image editor.
    My guess is the printer is opening your EPS file in Photoshop and the last such file he opened was at 72 PPI resolution. Photoshop likes to remember the last settings it has used.
  4. LMSigns24
    567
    1
    18
    Nov 1, 2007
    Pa
    Well, there are 3 photos in this file, but they are images that the customer provided. The printer is saying the entire file is blurry. This is how the file is being sent...... I created it, i am sending it to another business who sub contracts there work. So they are sending it to the printer. I recieved and email that said "PSD files you sent to us are 72dpi and appear blurry. I just want to make you aware that the files are low resolution" I am confused, because the file is not a psd, it is an illustrator eps. I am wondering if this file is being converted to a psd by sub contractor before it gets to the printer.
  5. Fred Weiss
    20,566
    423
    83
    Sep 11, 2003
    Olympia, WA
    Check your EPS and insure that the photos are embedded, not linked. It would also be prudent to send the photo files separately to the printer.
  6. Marie
    Marie Member
    390
    12
    18
    Jan 31, 2005
    Hattiesburg, MS
    Is eps what the printer requested? - or does he want a PSD (since he referenced that file type in the e-mail he sent you) - See if he will accept a PDF file. Usually, there are fewer problems with a correctly prepared PDF. You could save the file as a PSD, but it would be rather large . . . Good Luck :)
  7. a+signgal
    a+signgal Member
    27
    1
    printing problem
    Most printers require you to send files as 300ppi. They should be able to stretch the file if it is vector, but like others here have said if there it an image you need to readjust that image file.
    Sign Gal
  8. luggnut
    luggnut Very Active Member
    when i export eps from illustrator with transparency there is a box where i can chose the resolution. they have defaults in there low med and high. medium is the default. so if you have a object thats transparency has been adjusted you will be able to select a resolution. i found this when my strokes keep getting converted to outlines.
    i use that box to change the setting to custom so i can keep it from converting strokes to outlines. theres a check box for the convert to outlines if you chose custom resolution.
  9. ProWraps™
    ProWraps™ Guest
    well ****, theres your problem!
    i can almost guarantee they grabbed them off the web at 72 dpi. be thankful your printer is smart enough to give you the heads up. most would just print and charge you. let your client know these files are not sufficient resolution for true print work and that they need to provide you with a 300dpi file/s.
