Importing illy files into flexi 7.5
MVIP
Does anyone know of a good way to import illustrator cs3 files into flexi? I've tried .eps, but keep getting errors.
Thanks,
-Matt
MVIP
try 6...
Time to upgrade your Flexi... :toasting:
Maybe! Does the new version handle these files better?
I just use it for cutting vinyl and I am starting to use it as a pass thru to enroute for cutting digital contours on our cnc.
This is where the problem is showing up.
-matt
grafxxx
is everything converted to outlines or you could try to save it as a pdf. i can't even open cs3 files with cs2.
Fred Weiss
To my surprise I was able today to open a CS3 EPS (or CS4 ... not sure which) file in my Illustrator CS2. I tried a variation on Eric, The Vector Doctor's tip for PDF files. I simply used the place command on an open page and it came in perfectly.
