In illustrator ...Can't see the strokes !?!
Zazzess
Hi !
I don't know why I can't see the strokes or colored line and handles that surrounds the forms I do in Ai ... Ain't easy to work with at all ...
Anyone has a clue... whats happening ??
:U Rock:
Zazzess
Well there is something more...
I can't select two shapes and aline them together !?!
Why did I do ?? Any clue ?
:U Rock:
Bill Modzel
Are you selecting the total shape with the solid or the hollow+ arrow or are you
using the hollow selection arrow and only selecting a portion of the shape?
Zazzess
Ah ok !! I have to select the shapes borders so it can be selected... Not always been like that ... Is there a problem ??
petepaz
are you using CS5 because i had a similar issue. selected the 2 objects but it didn't align them correctly. it was like there was an other object selected and they were not aligning to each other. still not sure what caused it but when i restarted the program and tried again it worked. i have had that happen 2 or 3 times so if someone has the answer for that one i would be interested also
Zazzess
:goodpost: That's interesting ! I hope it don't happen to me :)
what happens to me is that I have to select the edges of the shapes or it wont be selected I can't select just the shape itself :help I haven't seen that before...
Bill Modzel
There are three selection arrows, which are you using?
Also, check view>show bounding box. I personally hate bounding boxes
but most people use them.
Zazzess
I use the black one or white one depending if I want to edit it or not ( ''v'' shortcut or ''a'')
