In Need for help with my colorcamm pc-600
Discussion in 'Roland' started by floater302, Jan 27, 2013.
  1. floater302
    floater302 Member
    191
    6
    18
    Aug 29, 2012
    iOWA
    I just purchased a colorcamm Pc-600 with a new head, and when i recieved itl and tried to do a self print test it goes all the way to moving the vinyl forward and backwards, it sounds an alarm with all the cartridge lights lit up and the busy light lit too, the guy said it worked when he shipped it...anyone have any solutions on what it could be?
  2. 401Graphics
    401Graphics Very Active Member
    I had one of those. I got it for free cuz it wouldnt power on. Just ended up being a loose cable inside. Sold it for about 1,600.
    That thing printed soooooo slow! and you would get about 6 sq ft of printing before it would run out of ribbon. I dont know why anybody would buy one.
    http://www.youtube.com/watch?v=ioKnmde_3Aw
    Anyways. good luck with it.
  3. FrankW
    FrankW Very Active Member
    1,305
    131
    63
    Oct 19, 2008
    Germany
    Have you set ribbons to the PC600?
  4. floater302
    floater302 Member
    191
    6
    18
    Aug 29, 2012
    iOWA
    Yes, i realigned the head to the cartridge, everything on it runs good until i try to do i self test or to print on it. I but it to do small jobs on it for now. i payed 1500.00 for this on with new head and alot of ribbons, the guys said he used it right before he boxed it to ship to me. but i couldnt find anything online like a sevice manual for it.
  5. woolly
    woolly Active Member
    644
    19
    18
    Sep 24, 2007
    Cornwall uk
    Don't know if its the same for the pc600 but on a 60 that sequence says it's missing a colour that it wants to use.
    All the carts are bar coded
  6. floater302
    floater302 Member
    191
    6
    18
    Aug 29, 2012
    iOWA
    the colors i have in it right now is as followed:Yellow, Black, magenta and cyan. Those should be the four default colors correct?
  7. floater302
    floater302 Member
    191
    6
    18
    Aug 29, 2012
    iOWA
    hey thank you alot, it ended up being the black had a wrong bar code on the cartridge.
  8. woolly
    644
    19
    18
    Sep 24, 2007
    Cornwall uk
    As time goes by and you get used to it you will be using different spot ribbons in odd carts to print what you want
  9. floater302
    floater302 Member
    191
    6
    18
    Aug 29, 2012
    iOWA
    ok, another question..lol i had it printing and when it tried to choose a different cartridge it keeped taking it then putting it back then stopped and beeped...why is it doing this?
  10. Sign Works
    Sign Works Very Active Member
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    Sounds like you may have the wrong cartridges and or bar codes, my experience is that anything other than genuine Roland carts are nothing but trouble. Make sure your process carts are CR-MR2 carts specifically for the 600.
    By the way, shipping is one of the worst things that can happen to a PC-600, shippers are way too brutal for how sensitive these machines can be. Other than that if you do not properly clean the print head immediatly after each print session you run the risk of destroying the print head.
    Good luck.
  11. floater302
    floater302 Member
    191
    6
    18
    Aug 29, 2012
    iOWA
    I know shipping anything like this is a chance, but he did ship it in the original box like it came to him. i just need to learn about these printers. i have a summa pro d750 cutter and that was the best money i spent so far.
  12. floater302
    floater302 Member
    191
    6
    18
    Aug 29, 2012
    iOWA
    I want to thank you guys for you help, I have the printer up and running.
  13. signmack
    signmack New Member
    14
    www.rolanddga.com has a user's manual for the PC600 on pdf
