Incomplete Cutting
Discussion in 'Roland' started by Farmboy, Mar 20, 2007.
  1. Farmboy
    Farmboy Active Member
    746
    6
    18
    Feb 8, 2007
    Auburn, NY
    First post here,
    On some designs my 300 does not cut all the way around. Sometimes on bumper stickers (3x10) it will not cut one end or miss a small spot on other decals. It seems to be hit and miss and no real reason for it. Thanks for taking the time.
  2. gvgraphics
    gvgraphics Very Active Member
    2,182
    2
    what brand cutter?
    Where in NY are you?
  3. canadianchef
    canadianchef Member
    110
    Jan 15, 2006
    Try This
    Hi Farmboy:
    Sounds like you need to do a environment match. That is located on your menu and it should be done at least once a day and sometimes more. Try this and hopefully it will correct your problem.
    Best Regards !
    Terry:Canada 2:
  4. Gino
    Gino Premium Subscriber
    33,134
    2,264
    113
    Jun 7, 2006
    PA
    Welcome to :signs101:from PA.
    You don’t mention anything in your profile about a 300, so I presume you have an SP300. Regardless of what you have, it sounds as if you need to apply more down pressure.
    Most vinyls [H/P, intermediate and so forth] have an inconsistent straight height to them if you would measure with a mic. Therefore, if your knife isn’t cutting deep enough at some points, it will only barely score it in those low areas.
  5. Farmboy
    746
    6
    18
    Feb 8, 2007
    Auburn, NY
    Sorry...yes it is an SP300.
    Plenty of downforce, it just does not cut one side of
    a decal such as a bummper sticker. It will cut around the rounded corners but will not complete the cut.
    We are located in Auburn NY.
  6. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    What RIP are you using?
  7. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    Are the....
    nodes connected when you zoom in on the artwork??
  8. BobbyFosson
    BobbyFosson Member
    401
    If you are using EPS files, you need to set the EPS Margin
  9. Farmboy
    746
    6
    18
    Feb 8, 2007
    Auburn, NY
    I use VersaWorks for the RIP.
    I will try setting the margin, not sure how :) but I will look into it when I get to the shop in the morning. Yes..nodes are all connected...but I will check that also.
  10. BobbyFosson
    BobbyFosson Member
    401
    In the Queue Settings, click on File Format on the left and set the Margin or border to 0.25.
    Save the settings and you are done.
  11. Kenny
    Kenny Member
    356
    Jul 15, 2003
    Texas
    From the top menu bar select "Edit"...from the dropdown select "Queue A Properties"...fourth button down on the left is "File Format", click-it, EPS Margin is at the top...I set mine at .04in
    You will now have a .04 margin around every instance of graphics you contour cut, and the cut will complete...small quirk with Versaworks, simple fix.
  12. Farmboy
    746
    6
    18
    Feb 8, 2007
    Auburn, NY
    Thanks all for your help. I hope to someday return the favor.
  13. Mac34
    Mac34 Member
    135
    I've had a Versacamm for some time now, but have really only started using it as of late (don't ask! LOL!). I was scared of my laminator, so to practice all I did was print and cut simutaneously. One thing that I have noticed is that when you print, and then immediately cut, you definately sacrifice cut quality! Then when you go to weed, it is like working with a warm, gooey substance! Since then, I've began to use my laminator. I've also began using Oracal products, (which seem to be great!). I'll print, wait, laminate, and then contour cut. It is a night and day difference in weeding! I have the SP300 with a Benes dryer for the front. I don't know alot of others that have it for the smaller Versacamm, but I'll tell you the dryer and moving to the Max inks definately saves on drying time!
  14. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Welcome to The BIG SHOW ! from the Pacific NW . . .
  15. TNT
    TNT Member
    48
    Apr 17, 2007
    I have the same problem as Farmboy and tried to correct it in the Format EPS setting, but that setting is not activated and will not let me change it. Any idea on how to fix that?
  16. Sign Works
    Sign Works Very Active Member
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    Set it as Kenny described, I set mine to .10, I have heard that you can set it as low as .01
  17. 2NinerNiner2
    2NinerNiner2 Very Active Member
    1,122
    Mar 21, 2006
    Calgary, AB
    I have also had this (or a similar) issue where it would not cut the leading edge of the output. Everything else would cut fine, be it 300 small labels or 1 big complex graphic. My setup is a SP-300/ColoRIP 2.2, EPS or PDF as file type. In my case, I found that this only occurred when I was trying to be 'cheap' by rewinding the media with the arrow keys following the 'set up sheet' and then setting the base point, attempting to 'save' 2 or 3 " of material :) Have nevr had it happen otherwise; always cuts fine, but as CDN Chef says, I always do an EV match.
    Cheers!
    Lyle
  18. BobbyFosson
    BobbyFosson Member
    401
    You can not make the change in the individual job settings... The EPS Border must be changed by editing the Queue Settings...
  19. Mason
    Mason Very Active Member
    2,037
    Aug 11, 2005
    Farmboy, Ive had the same problem, seems like its more Versaworks recognition of the cutlines than an issue with the 300. Increase the stroke weight of your cutline to 2 points in your design software and you should remedy that problem. Also if your contour cut line is located on the same layer as your artwork in the eps file, move it to the uppermost(top) layer.
    This worked for me and I havent had that problem since.
