ink card not loading credits,spitfire 65
Mr Moss
hi guys,i managed to convert xerox 8265 to mutoh spitfire now i cant get ink credits to load into the printer(i have a card reader to write the cards with),i was adviced to use type 1 cards for the printer but it does not show its detecting it when i insert it even after pressing enter for it to read.it would just write no valid card found.
can rh3 extreme use the same cards as spitfire extreme and vice versa?
i dont know what to do do.tried everything i can possibly imagine.
Mr Moss
could this be the cause why it is not reading any cards i insert on it?
that shows up after i put special code on the printer.
is the mainboard locked?,what can i do?
Mr Moss
i have managed to load credits on to the printer,had to change from eco to mild solvent.
now i have another challenge,even with ink credits loaded it still shows "ink status not filled (all)"
any ideas?
if anybody needs help converting their xerox 8265 to spifire feel free to ask
Mr Moss
hopefully someone will shed some light into this.
is it as simple filling ink on the printer?
i currently have cleaning solution on the ink lines to try preserve the heads
wunder
start ink load procedure.......and disconnect the inkpump motor connector (grey plugs) and wait that system ready with the inkload procedure ! or what you like to do now ?
Mr Moss
thanks for the info but which one is the ink pump and when do i disconnect the grey plugs?
