Inner contour cutting with Flexi
Discussion in 'Flexi' started by Flame, May 4, 2006.
  1. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Not sure where to put this question, so I'm posting it in both the printing section and in here.
    I've never used any Flexi program before, and I just got 7.6v2 a couple of weeks ago. I am printing with a Mutoh printer and cutting with a Graptec FC7000 plotter. My problem is...
    How do you cut inside of an image? I added cut lines to the outside of an image, and then to some strategic holes inside of the image. After I had printed and laminated, I ran it through my plotter and only got the outside cut. None of the inner holes. Any idea what I'm doing wrong? It's stumping me.
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    CONTOUR CUTTING my friened..
  3. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    Look for Contour Cutting under Effects before applying the Contour Cut make sure the box is checked with holes then apply. If you need to you can Separate the Contour Cut and make sure that the cut looks right if every thing looks ok then just undo to the point where the Contour Cut was applied.
  4. Flame
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Thanks Dudes. Checking that box was all I needed to do. Sorry for the simpleton question, but Flexi is all new to me and I HAVE to use it as it's running my new printer. If I can't work Flexi, I can't make graphics. That simple.:cool1:
