Installing a 4x6ft wood sign
gnubler
Sounds plausible, except I saw mention at one point that he's like 6'7" and 300#. Calls for an excavator, not a shovel.
fixtureman
Here you would dig the hole 36 to 40 inches deep and pour in a base of concrete. Then when that is set put your posts in and backfill. Also they will use sona tubes put the posts in them and fill with concrete. I have seen to many posts that were set using concrete that the frost had lifted them up
gnubler
There's a great thread on here somewhere about the drill auger for post hole boring. I think it was started by Tex? Like others here I have to contend with extremely rocky soil. Digging two post holes is usually not an easy feat.
gnubler
Yes. The "foreman" holding their shade umbrella probably ran out for a cold drink to take a break from all that hard umbrella holding.
Texas_Signmaker
Very Active Signmaker
I've tried a hammer drill in dry clay and it's like concrete...doesn't break up. I have a breaker bar on the truck and that's the only way I found
Notarealsignguy
Arial - it's almost helvetica
Let's be honest. There's a right way to dig a trench and if you're gonna make a career out of it, you can't start throwing dirt and risk wrenching your back. So I give these guys an A+
Johnny Best
Brother from another mother. You must have the minority jobs wrapped up, you could even be the US Vice President.
boardboy330
Here in VA we go 24" to 30" deep, depending on the height of the sign. It sounds like it will be relatively low to the ground. If you feel the need, use sonotubes, but a hole with concrete will suffice. This is just my opinion.
