Custom_Grafx
Hi all,
I recently upgraded my pc - with a bit of help as usual from Choucove (Thanks again).
Just wanted to note some specs and config here in case any one else is upgrading, with similar software/machinery and wants to know about compatibility and the such, and about performance.
Hardware;
intel 2600k i7
crucial m4, 128gb sata 3 SSD (for windows + program files)
corsair vengeance 1600mhz - 4x4gb - 16gb total RAM
seasonic 650W PSU
Asus P8P67 v3 Pro m/b
2TB standard sata2 HDD (for data)
1GB ATI 5970 dual DVI
Antec 300 tower (from memory)
CD/DVD combo drive etc etc
Software;
win7/64bit
Adobe CS4
Corel X3
Versaworks
MS Office
Equipment running off this machine;
Roland VS-640 - ethernet
50W ULS laser - usb
Xerox Docucentre - ethernet
i1 extreme/Uv cut and bundled software i1 match/share - usb
Performance;
A very satisfactory start up and application response time. I have bridge, PS, Ai, versaworks, mail and calendar apps on startup and it barely affects boot time. I am up and running in seriously no time.
For example, boot time for all the above, after punching in my login and hitting enter, is about 20 seconds.
Having all the above open, even with a bunch of files open in PS, Ai, etc, has no effect that I can feel on any part of the system's performance.
I was a random versaworks lock-up sufferer. I have not had one lock up yet, and in the last 2 weeks, have been putting through some big files, and they are still in the queue and I can't feel any difference in performance whatsoever.
Issues encountered;
The i1 extreme has some connectivity issues with Win7/64. I found more info on the xrite website but it wasn't easy enough to understand. The final fix was to copy and replace a .dll file to the i1match prog dir so that it could recognise the device.
In my old XP, I could simultaneously have the machine use the i1 on i1 share/match as well as in versaworks. Now, it's one or the otther. Apparently it's some security measure or something... I'm not that tech savvy. The work around, is to unplug then replug the device, and the program you want to use it in will then recognise it.
Versaworks - no issues at all.
ULS Laser and interface software / drivers etc, no issues at all.
Adobe - no issues at all.
Corel - no issues at all.
What would I do differently?
If I could have afforded it, a bigger SSD. But I am still happy with 128GB for now - especially since I have a 2TB for my data. I think bigger than 128 at the moment is still not good enough value, and when prices come down, will upgrade that to a bigger SSD, and use the 128 I have now as a scratch disk or something.
Things to look out for;
SSD!!! Buyer beware there are far too many different types around, and they are all called SSDs but beware, they are not all FAST!
What do I still need?
I still need to get myself a second monitor... maybe later this year, maybe not... I get by, but it would be nice. (hence the dual dvi card).
Questions;
I'm sure I left something out of this, and will add info to the thread if I think of anything. Also, if you have any questions or comments about upgrading to a similar system, feel free to post here and I can help out hopefully.
And by the way... Need for Speed doesn't play too badly on this thing either
Hardware;
intel 2600k i7
seasonic 650W PSU
Software;
win7/64bit
Adobe CS4
Corel X3
Versaworks
MS Office
50W ULS laser - usb
Performance;
Issues encountered;
Questions;
