Is there a way to auto nest multiple objects inside one shape?
bigben
Not a newbie
So out of curiosity, I was poking around in Illustrator to see if it could be done there. You can use Envelope/Envelope Distort to nest objects in a shape like that but it distorts all the objects to fit. Since there is a plug-in for Illustrator that will do that properly, I figure there must be a way to do it manually without distortion but I can't seem to find it. Does anyone have any clue about doing it in Illustrator?
I would also like to know the answer to this question. :popcorn:
FrankW
Look at the software package Enroute. The company I work for uses Flexi-Sign because it is directly compatible with Enroute. Which is the software package this was supplied with our first router.
Yes. And Flexi is famous too for exporting excellent DXF-Data for use with different apps too.
Nat
Disappointed that this Thread had an end !
Educational, Helpful, Memorable, With a bit of(For Lack of a better word) Zest!
Nat
SignManiac
Profile Lab and Aspire have good nesting modules but expect to pay. But when optimizing CNC files, they're worth the investment.
bob
While it does export dxf files, they are far from excellent. Flexi often has difficulty dealing with arcs when exporting this format. It's been my experience that multi-point arcs tend to be somewhat less than smooth from point to point. Corel does a far better quality dxf file.
thewvsignguy
Try This in Flexi Pro:
Is this feature not available in Flexi Designer 10.5.1?
I don't see it in my menu. Or am I blind.....
ChrisN
Even though SAi says this about FlexiDESIGNER,
Get all the design, layout and image editing features of FlexiSIGN-PRO,
it is not true. FlexiDESIGNER does not have some features FlexiSIGN-PRO has. A few I've noticed (on FlexiDESIGNER Cloud 11 sp6) include true-shape nesting and i-cut marks.
thewvsignguy
Thanks for that info, it's not a deal breaker but good to know. I like setting up most of the production files when I can (designer), that seems like a neat trick. I'll just use it on the RIP computer.
