You'll need to get into service mode and print the head bias alignment test, then mechanically adjust if it says so, after the mechanical adjustments, you will want to do the software adjustments, vertical, horizontal and bidirectional last. All of these are accessible in the service mode. I'm assuming the tests are the same as the soljets. I would find a service manual so you aren't making any assumptions.
