Issue with either Versaworks or Adobe Illustrator.
MIPDan
Versaworks is no longer seeing my cutlines on new files I make as of Wednesday. I am doing the same process I have done for a few years, but instead of seeing it as an instruction the software is only seeing a pink line. All my old files still work. I don't know if I accidentally flipped a setting or if there was a software update to Illustrator or Versaworks that is messing things up. I am attaching an .pdf file (couldn't upload eps). Can anyone look to see if there is a setting that I am missing? Thanks for any help!
  • Zerbe Snacks.pdf
Graphic Extremes
Knows To Little
The file is set up correctly, I would label the cut layer and Cut-Layer but not necessary.
Four different programs I use to cut see the cut line correctly. I would reinstall versa-works to the latest version, The program may have become corrupted.
Hope this helps you
MIPDan
That definitely locks it in on VersaWorks. Thanks for your help. It did the same thing with JPG files a few months back. It would accept any jpgs before a certain date but would see anything newer as corrupted. I will reinstall.
netsol
is an update at fault?
since it happens after a certain date
CSOCSO
I don't hate paint, I just overlay it.
No, your file is incorrect. It's missing the cut contour swatch. It looks like you deleted all the swatches from the file. Any time you work with specific colors ( Roland spot colors, pantone colors, cut contour, etc) you need to keep them in the swatches tab. ( Click on Window and select swatches)
Boudica
^^ This. the color of your cutpath needs to be a spot color, named CutContour. Try pulling this file in...
  • Zerbe Snacks-Spot.pdf
Graphic Extremes
Knows To Little
The first time I opened the file it showed as a spot color and your right now it is showing as a processed color, It needs to be change to a spot color. Don't know why Versaworks showed the cut line for me at frist.
