Take the head cables out of the printer with the machine turned off, unplugged and discharged. Also unscrew the two head lock shafts (black plastic with flat head screw tops) completely out. You will see two screw holes that do not have anything in them that match up with the metal bracket that holds the lever. There are two rectangular indents between the screws that match up with the protrusions on the back of the lever. Place the protrusions in the rectangular indents and tighten the screws. When you push down on the lever it should raise the head carriage up slightly. If it does, put the head lock shafts back in and you should be good to go. Sorry for no picture but this is the best way I could describe it.
