classicgameswi
I have a new to me JV3 160-SP with two bad channels on the board (only the left half of the cyan and yellow print) and two partially clogged heads.
The shop I bought the machine from sent the boards into MacMedia and that did not solve the problem. (Not blaming them, previous owner may have re-damaged the board)
I checked over the board and found a bad transistor, but i dont hold out too much hope that a new one will fix it, as it is the only one that was replaced when the board was replaced. So I am wondering if there is any way I can get it running in the mean time.
Could I set up the machine with CMYK running on two heads?
The cyan and yellow channels are the ones with bad channels.
I was thinking if i set the machine up as CMYKlclm i may be able to do this.
Anyone try it?
Also, does anyone have experience running SAM ink?
Anyone try it?
