Jv3 Head Movement
Discussion in 'Mimaki' started by diarmuidrobson, Sep 4, 2012.
  1. diarmuidrobson
    diarmuidrobson Member
    32
    Jan 16, 2012
    Ireland
    Quick Question for the jv3 owners...
    Does the complete head lift up and down freely, like in a rocking motion
    I am able to lift my printhead assembly and rock it up and down about 10mm or so. Printer tech suggests to me theres a bearing worn or something but i am thinking they all have this play in them, would i be correct?.
  2. artbot
    artbot Very Active Member
    3,164
    10
    38
    Feb 18, 2010
    Houston TX
    that's the way it's supposed to be. the carriage is sitting on the rails held down by gravity. but, it can be rocked upward a bit from that position.
  3. ligonr
    ligonr New Member
    10
    the carriage move like that but if you have to much play in them they will rock back and forth in the rails and cause the head to bind and wear your Y motor out
  4. Tekkie1
    Tekkie1 Tekkie of Many Things
    98
    1
    8
    Apr 27, 2012
    Australia
    Within reason it should..basically look under the head carraige assy and see if it looks parallel to the platen if it does ok. If it looks like it is facing down then you need to replace 2 bearings at the back of the carriage which is not hard but lots of things need to be unscrewed and cables removed to get at it. I have done about 5 of these due to the now age and amount of use that the JV3 has had.
    I have also come across one head where the rear mounting screw of the head was crossthreaded not allowing for the head to be held tight and this then meant that the head moved up when capped.
    Tekkie1
  5. diarmuidrobson
    32
    Jan 16, 2012
    Ireland
    Having an intermittent problem where the heads will seal for a few days and then won't seal, is this excessive wear on the bearings likely to cause this sort of problem?
    Does it give you tolerance play values in any of the manuals for this wear?
    Is there any sort of alignment marks for the belts to be put back in place like a timing belt or is it a straight on and off.
  6. Tekkie1
    98
    1
    8
    Apr 27, 2012
    Australia
    There is a plate and 2 screws on the end of each end of the belt so you cant go wrong its behind the head carriage.:smile:
