StopSignGraphics
I just thought I should share this and possibly save someone else the headache and a few hours out of their life.
Replaced the dampers on magenta on my JV33 when I noticed what looked like some possible ink starvation on a heavy red print. After changing the dampers, magenta wasn't printing at all.
Went through the usual troubleshooting assuming that I lost compression on the print head. Pump was working correctly, capping station was clean and no tears in the rubber, etc...
Tried doing the syringe pull to get ink into the print head, nothing seemed to be working. Went deeper into the machines plumbing. Everything was checking out fine.
Was about ready to throw in towel and happened to notice the smallest drop of ink on the compression fitting on top of the quick connect for one of the magenta dampers.
The compression fitting nut was loose! Just loose enough that it wasn't seating well and letting a little air into the system.
Anyway after tightening the nut and going through the normal maintenance procedures the printer is back up and running.
Not sure if anyone else has experienced this but just thought it might save one some aggravation later on.
~Chris
~Chris
