Typestries
Hey Folks......a word of caution. If you run a roll of banner material to the end, and the banner detaches from the roll with the tape that holds it to the roll......it will stick to the inside of the machine! I got lucky, and was able to slide a piece of .020 poly under the banner from the front, and break it loose. BUT, it's a known issue, and if the poly trick does not work, IT REQUIRES TEARING the ENTIRE machine apart! So, proceed with caution!
-Rick
-Rick
